TPS voltage....
Old Dec 19, 2007 | 09:37 AM
spinz71's Avatar
Default TPS voltage....
What voltage should the TPS be reading at idle? '02 5.3, cable TB.
TIA
Old Dec 19, 2007 | 10:47 PM
DrX's Avatar
DrX
Here' my second try. I originally copy/pasted from the wrong section.
From the manual:
"Circuit Description
The throttle position (TP) sensor is used by the powertrain control module (PCM) to determine the throttle plate angle for various engine management systems. The TP sensor is a potentiometer type sensor with three circuits:
  • A 5-volt reference circuit
  • A low reference circuit
  • A signal circuit
The PCM provides the TP sensor with a 5-volt reference circuit and a low reference circuit. Rotation of the TP sensor rotor from the closed throttle position to the wide open throttle (WOT) position provides the PCM with a signal voltage from less than 1 volt to greater than 4 volts through the TP sensor signal circuit. "
Old Dec 20, 2007 | 08:51 AM
spinz71's Avatar
Thanks DrX. So .51v at idle is okay. Thanks again.
Old Dec 20, 2007 | 09:01 AM
DrX's Avatar
DrX
Seems OK. Throttle should be closed and the IAC should be taking care of idle airflow. If it falls too low it would trigger a DTC. That's right where the electronic throttle TP sensors are at if you hold the blade fully closed.
chvy=power
Oct 20, 2015 09:08 AM
JCW
Sep 22, 2015 03:59 PM
Pontiac Derek
Sep 19, 2015 01:49 PM
Pontiac Derek
Sep 18, 2015 09:02 AM
smokeshow
Aug 23, 2015 08:23 PM
