Tough E85 Cold Starts in warm weather, can someone look at my timing table?
Old Mar 30, 2016 | 05:32 PM
  #21
Atomic's Avatar
I have a gauge for that
E85 will want a bunch of fuel on cold starts. There's a reason it's diluted so much in winter with gasoline.
Turn the key to on without starting to let the wideband warmup then crank over to start and the Wb will pick up the first few seconds.
Old Mar 30, 2016 | 05:38 PM
  #22
lxcoupe's Avatar
We aren't on winter blend here, ethanol gauge shows 83%
Old Mar 30, 2016 | 06:30 PM
  #23
George C....'s Avatar
Formerly ScreamingL
Cranking ve for me is 100%
And my open loop fuel is 1.4 scaled down to 1.0 at 158*
From 20 to 100 kpa
So example from -22 to 14 is all 140s then i drop down..
Old Mar 30, 2016 | 07:32 PM
  #24
GMCtrk's Avatar
The pcm doesn't use the open loop fueling for startup fueling
And your truck is too rich George warmung up , its sitting at 10.6:1 afr
Old Mar 30, 2016 | 07:42 PM
  #25
Formerly ScreamingL
It was 25* and snowing...when its 40 its less afr....when its 60* its 13s
Truck follows that table and always has for me
Old Mar 30, 2016 | 08:29 PM
  #26
Atomic's Avatar
Thats my point; its easier to start E85 when its not really e85 and has gas mixed in. You would never be able to start actual E85 in the really cold unless they dilute it.
Old Mar 31, 2016 | 12:12 AM
  #27
lxcoupe's Avatar
I see what you're saying. Winter blends would actually be easier to get it to light off, being they would only be E70 or E75 or whatever. So... does anyone have a first line suggestion? I will admit to easily being the least knowledgeable "tuner" on this forum, it's embarassing actually. I turn wrenches and not much more
I was doing some searches, and found a post on a Cobalt SS forum, and I'm thinking of changing my cranking fuel table to look like this (multiply by 1.9):
Old Mar 31, 2016 | 05:51 AM
  #28
Formerly ScreamingL
I dont mess with cranking time
Old Mar 31, 2016 | 07:53 AM
  #29
Atomic's Avatar
Ill be honest, the cranking tables have always kind of baffled me somewhat. Just keep adding 10% until it starts
Old Mar 31, 2016 | 08:37 AM
  #30
Formerly ScreamingL
Lol....
If he logs cranking afr hell see his issue
