Tough E85 Cold Starts in warm weather, can someone look at my timing table?
Old Mar 29, 2016 | 09:12 PM
GMCtrk's Avatar
i dont use o2s
Old Mar 29, 2016 | 09:13 PM
George C....'s Avatar
Formerly ScreamingL
Also in video youll notice pass exhaust is missing...had mishap where it got caught under tire
Old Mar 29, 2016 | 09:17 PM
GMCtrk's Avatar
racetruck problems
Old Mar 29, 2016 | 09:21 PM
Formerly ScreamingL
Yea street tires rubbed wrap...i backed up and all she wrote..was fixed a couple days later at tune of 180 in materials
As for posting tune hard to sign on with laptop cause of my baby daughter. Makes tbose changes above as it will help
Old Mar 29, 2016 | 09:24 PM
GMCtrk's Avatar
ironically, i never had problems with cold starts. just hot starts. crank time of about 2-3 seconds. not enough to make a big deal of
Old Mar 29, 2016 | 09:36 PM
Formerly ScreamingL
What is afr for a hot start? Usually starting issues on e85 is 9.0 afr or 17.0...if anywhere else it will run and idle
Old Mar 29, 2016 | 09:40 PM
GMCtrk's Avatar
the ngk wideband has a 20 second countdown. starting afr not able to be known
Old Mar 29, 2016 | 09:51 PM
Formerly ScreamingL
What is cranking ve?
What are you using for open loop target?
These 2 are important from my experience
lxcoupe's Avatar
Same with Innovate, Autometer, AEM and pretty much all of them but most dyno's will use tailpipe probe so should be able to log cranking afr's no?
Or what about hotwiring wideband to bypass key-on 20 sec countdown.
Old Mar 30, 2016 | 05:27 PM
lxcoupe's Avatar
Any insight George?
