Torque management?
Torque management?
Well i finally did the swap and the trucks running good. The only thing is it seems to be held backnor limited till about 35 or so? I can stall it up to 3000 or so and it wont take off that great and wont break a tire loose from break stalling or even around a corner? It seems to be shifting fine. It comes alive 40+ and ahifts hard outa 1st? Idk whats wrong but with my old set up i couldnt do anything but roll into it without breaking them loose?
Heres my new. And old set up
New: 4l80e with a 2b 3000 multi disk
Old: 4l60e with vette servos and a 3200 single disk?
Mods: are in my sig
Mods: are in my sig
In your 80e the ratios look like this....
1 2 3 4 R
2.48 1.48 1.00 0.75 2.07
Vs in your 60e they looked like this.....
1 2 3 4 R
3.059 1.625. 1.000. 0.696 2.29
Get it? Your 1st gear will feel as tho you swapped to 3.23s where as the other gears will feel mostly the same as before. Also the driveline has a little more drag from the increased size and weight of the 80e. It's a very small price to pay for the increased strength.
1 2 3 4 R
1 2 3 4 R
Humm i guess irs possable? But why would it seem.lile it has more torque with the tow hual.on? Also thw dribe shaft was the stock one just had it shortened alittle ovet 2 inches. But i will say its longer tho shifts outa 1st at about 64 mph and shifts eff n hard! I am planning on trying to go turbo in about 6the months should i keep my gears the same?
