Torque Management 08 GMC Sierra
Old Sep 13, 2008 | 10:14 AM
MNC5's Avatar
I'd ask them to refund you for the custom tune and find someone else to tune it.
WOT tuning is the easiest part of tuning. Its the part throttle and low rpm WOT tuning that takes some time to dial in. Without proper tuning you can break parts. Just because its a pooch down low doesn't mean its a safe tune.
Good Luck
Old Sep 13, 2008 | 03:45 PM
Vmax2007's Avatar
I don't think your problem is TM. I have 100% of my TM removed (TM tables are all zeroed out). My truck runs like a raped ape, but it is still a pig off the line. I was told that there is still a throttle position rate table (not sure of it's exact name???) that is locked and unable to be altered. So, the rate at which the throttle opens is still limited to GM's stock tuning.
Old Sep 13, 2008 | 03:52 PM
chevrolade's Avatar
Get Rid Of The Handheld Programmer And Get A Custom Tune.
Old Sep 13, 2008 | 03:58 PM
kbracing96's Avatar
Go RE-READ his FIRST post... he said he just had it DYNO TUNED with HPT and they told him they couldn't remove the TM as it would cause problems...
Old Sep 13, 2008 | 07:41 PM
shakinlm7's Avatar
Get your money back and find someone else to tune it! I was shooting the **** with a local tuner who just had an 08 vet come in for some work. He said he had a hard time with the TQ management but he was able to figure it out. He uses EFI live for the most part so you might need to find a tuner that uses it.
Old Sep 13, 2008 | 07:46 PM
Truckshop's Avatar
contact justin with blackbear performance. you are in the same state i just do not know how close he is to you. he is also a member on this board.
Old Sep 13, 2008 | 08:05 PM
XLR8NSS's Avatar
Adkoonerstrator
It is not related to any throttle position tables. I know EXACTLY what you are talking about and took care of it. I need to go back over my last NA tune and see what tables to look at, can't remember offhand.
Old Sep 13, 2008 | 08:32 PM
XLR8NSS's Avatar
Adkoonerstrator
Well, there was a LOT of changes I made and I don't remember what changes did it but, I think a lot of it had to do with the burst knock table, just zero it out.
If I remember correctly it was a combination of the spark tables(go over them all), torque reduction/control(ECM) tables, torque management(TCM), and PE.
Old Sep 14, 2008 | 10:06 PM
rockerjoe2008's Avatar
Thanks I'll show this to the tuner and see what they say. If they aren't sure they can fix the problem I'm not driving all the way to durham so the can @#$% up my tune again.
I may just try to get my money back and find someone who knows what they are doing. Maybe black bear can help me.
Old Sep 16, 2008 | 11:17 AM
Denali Dude's Avatar
I have the Same problem as well My 08 CC Doesnt do a burnout even when the Stabilititrak is off And under 3000 rpm It cant carry it self I was told this is normal But this happened after I custom tuned Some of the guys told me my tuner maybe did something with the abuse mode Because i've got 50% of TM removed.
I got the Converter now but havent installed it yet I will install it along with the cam and see What will happen next
