Torque Converter Cycles when reading data from PCM
Old Sep 16, 2013 | 10:24 PM
Suburbazine's Avatar
Default Torque Converter Cycles when reading data from PCM
Got a small oddity here. Tuner doesn't know why it is happening.
When I plug in my scan tool to read the data (generic engine operational data, nothing fancy) while driving, the torque converter begins to cycle off-on...off-on...off-on...etc.
The TCC will stay engaged as long as the engine is under practically no load (like going downhill) but then when climbing a hill the cycle begins again. The TCC is supposed to be staying locked at the given throttle angle and load values, but what could a scan tool (read-only, I would add) be doing to freak out the TCC?
I have only noticed this issue since I swapped in the 80E and used Frost's 2-relay conversion harness.
Old Sep 18, 2013 | 07:52 PM
BigHate's Avatar
I had TCC issues when I swapped in my 4l80 but it was slightly different as mine would not be commanded on over 60-65mph. I had a p0300 misfire code that i found out prohibited the TCC function.
does the scan show it bieng commanded on off on off? can you override the PCM and command it on?
Old Sep 18, 2013 | 07:53 PM
BigHate's Avatar
i have the segment swap BTW
Old Sep 18, 2013 | 09:41 PM
oakley6575's Avatar
Log total misfires and see if that is the cause.
Old Sep 20, 2013 | 04:29 AM
Misfire detection is disabled in the PCM and the scan tool is not capable of reading that data in realtime.
Old Sep 20, 2013 | 05:56 AM
03sierraslt's Avatar
I have heard of a couple oddities associated with the relay method, this is a new one.
TAPyvehc93
Jul 23, 2017 10:54 PM
OLD BULL
Aug 1, 2015 05:00 PM
BennyB
Aug 1, 2015 08:48 AM
KyleW707
Jul 29, 2015 08:17 AM
JordanH
Jul 14, 2015 03:46 PM
