Tip in wot timing drops..why?
Been doing some tuning on my new 6.0. I always thought the 5.3 was a dog off the line then I got this 6l and it has the same initial dog feeling going wot from a dead stop. Well I've went through my logs of the 5.3 and of the 6.0 and I'm finding that timing is dropping to 2-4* when you go wot. The cell that its going to is set for around 17*. So why is it loosing so much timing? Where can I look in hpt to correct this?
First see what's pulling the timing like mentioned.
My guess is it's a function of the engine torque management. There is a few options it uses to do this (fueling, spark and throttle). Poke around there and see if those are enabled.
I need to down load a lq4 tune so I can look at some of the timing tables. I'd also like to compare a 2500 silvy to a Denali. Same motor but the Denali is rated higher. It's got to be in the tune. I figure timing tables are lower for the 2500 due to its work ethic so to speak.
