Tip in wot timing drops..why?
Old Apr 9, 2013 | 08:11 PM
TURBHOE's Avatar
Default Tip in wot timing drops..why?
Been doing some tuning on my new 6.0. I always thought the 5.3 was a dog off the line then I got this 6l and it has the same initial dog feeling going wot from a dead stop. Well I've went through my logs of the 5.3 and of the 6.0 and I'm finding that timing is dropping to 2-4* when you go wot. The cell that its going to is set for around 17*. So why is it loosing so much timing? Where can I look in hpt to correct this?
Old Apr 9, 2013 | 08:43 PM
03sierraslt's Avatar
Have you logged to see if burst knock is pulling it?
Old Apr 10, 2013 | 04:04 AM
TURBHOE's Avatar
No I need to do that.
Old Apr 10, 2013 | 05:09 AM
ak2007r6's Avatar
First see what's pulling the timing like mentioned.
My guess is it's a function of the engine torque management. There is a few options it uses to do this (fueling, spark and throttle). Poke around there and see if those are enabled.
Old Apr 10, 2013 | 08:46 AM
TURBHOE's Avatar
All disabled. I fixed burst knock before for wot but I don't recall doing anything under 3000. I'll check it out tonight. It was late last night so I said **** it, was too tired.
Old Apr 10, 2013 | 08:47 AM
nonnieselman's Avatar
Burst knock.. gotta be.. i removed 75% of mine and it reacts faster now
Old Apr 10, 2013 | 09:01 AM
TURBHOE's Avatar
I think this thing would be a monster off the line if it weren't for that dip. It's a mean upside down spike lol
Old Apr 10, 2013 | 09:09 AM
TURBHOE's Avatar
I need to down load a lq4 tune so I can look at some of the timing tables. I'd also like to compare a 2500 silvy to a Denali. Same motor but the Denali is rated higher. It's got to be in the tune. I figure timing tables are lower for the 2500 due to its work ethic so to speak.
Old Apr 10, 2013 | 09:17 AM
Thats the 2500 LQ4 vs the denali LQ9. 9.4cr vs 10.0cr..
but yes the LQ4 timing is quite low.
Do you use HPT or EFI Live?
Old Apr 10, 2013 | 11:01 AM
TURBHOE's Avatar
No the Denalis have the lq4 the escalades have the lq9.
