Timing for economy
Ive always heard at very light loads up to around 50 degrees. The stock timing is in the 30-40 degree range in the highway crusing cells.
I havent noticed any diffrence in advancing timing in the cruise areas. I would think the around the stock timing would be best untill you get into the higher arimass and pe mode. But a bigger cam might require some more timing in the cruise areas but then a higher compression ratio might require a little less.
Im sticking with a little added on to the stock table for cruise. GM spent more time than anyone else tuning.
tweeder
Sep 18, 2015 11:02 PM
Suburbazine
Aug 9, 2015 01:17 AM
