Timing for economy
Old Mar 21, 2008 | 11:50 AM
Stoichiometric's Avatar
Default Timing for economy
How much advance do you guys like to run on the HWY for best economy?
Old Mar 21, 2008 | 01:10 PM
cmitchell17's Avatar
Ive always heard at very light loads up to around 50 degrees. The stock timing is in the 30-40 degree range in the highway crusing cells.
I havent noticed any diffrence in advancing timing in the cruise areas. I would think the around the stock timing would be best untill you get into the higher arimass and pe mode. But a bigger cam might require some more timing in the cruise areas but then a higher compression ratio might require a little less.
Im sticking with a little added on to the stock table for cruise. GM spent more time than anyone else tuning.
Old Mar 21, 2008 | 09:49 PM
I have about 30 degrees at 70MPH right now.
Old Mar 22, 2008 | 03:30 AM
TurboGibbs's Avatar
I'm currently running 45*. I haven't tried any more yet.
Zizzle
Oct 19, 2017 08:44 PM
2500ZL1
Jan 25, 2016 06:30 AM
tweeder
Sep 18, 2015 11:02 PM
Suburbazine
Aug 9, 2015 01:17 AM
Cowboy Tom
Jul 21, 2015 10:29 PM
