throwing codes p0151, p0300
Old Jun 19, 2006 | 01:39 PM
Grumpy5.3's Avatar
I have seen several trucks and vans with these codes and the o2 sensor is the actual cause of the misfire, there is actually a bulletin about it
Brian
Old Jun 19, 2006 | 04:33 PM
86MC_SS's Avatar
Ok after checking the wiring for the O2 sensor during my lunch break ..and resetting the codes...the only code that pops up now is the p0300 code.
I will fiddle with it more later anyone else have advise?
Old Jun 19, 2006 | 04:46 PM
BlownChevy's Avatar
blownerator
25 Year Member
I see you have replaced the wires, how about the plugs?
Old Jun 19, 2006 | 05:15 PM
86MC_SS's Avatar
I replaced plugs and wires yesterday as well. I double checked the plug connections again today and all was fine.
Old Jun 19, 2006 | 06:13 PM
BlownChevy's Avatar
blownerator
25 Year Member
If you wanted to bring it out to chatsworth we could take a look at it for you.
Old Jun 19, 2006 | 06:54 PM
86MC_SS's Avatar
PM'd Blownchevy
Old Jun 20, 2006 | 03:09 PM
86MC_SS's Avatar
EDIT:
So I checked all spark plugs, wires, coil packs, and injectors. I checked for vacuum leaks and any loose connections and nothing. I used the old school water hose across the intake and vacuum source technique on different areas to check for vacuum leaks and the truck had none.
To check the coils I unplugged each plug wire from a coil one at a time while the truck was at idle and they all had spark.
To check the injectors I unplugged each injector one at aa time while the truck was running at idle and it really had no affect on the truck. It was still missing and not firing properly. Is that normal?
I am at a loss...
Old Jun 21, 2006 | 09:57 AM
86MC_SS's Avatar
So my O2 sensor code came back on...
p0151 - O2 Sensor Circuit Low Voltage (Bank 2 Sensor 1)
After lots of reading and searching and gathering as much info as possible. I retraced my steps to what started all this. At first I only had one code for...
...then I bought a new bosch O2 sensor to "fix" this problem. After replaced the bad O2 sensor with the bosch one I reset my computer and all was fine for a couple hours. The code came back on after a while and things got worse. I had more codes for...
p0300 - Random/Multiple Cylinder Misfire Detected
P1153 - Bank 2 Fuel Control Shifted Lean
....plus my O2 sensor code now as well. As you read I checked plugs and wires and everything else that would cause a random misire. Remembering that I read someone moved there post cat O2 sensors to the front of the cat , I had nothing to lose and tried it. I cleaned off my "bad" O2 sensor and stuck it after the cat...so basically I swapped O2 sensors. I reset the computer and turned the truck on and drove it for almost an hour and no more codes. The bosch sensor was junk and caused more headaches then needed. I will be buying GM O2 sensors and replacing both primary O2 sensors next week.
BOSCH SUCKS!!!
Pimpinpete
43
Dec 22, 2017 08:13 AM
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
JordanH
Nov 6, 2015 07:42 PM
