Terminator X Max Install
Old Jan 18, 2020 | 12:42 PM
Lou99tahoe's Avatar
Default Terminator X Max Install
I am installing a Terminator X with Tranny control for a LS turbo swap in my 1999 2dr Tahoe, and want my gauges to work. I was thinking about splitting the Holley signal wires to work my factory gauges. The oil sensor I assume I can split. The coolant sensor, I read that 98 Camaro is a 3wire sensor that has 1 signal wire for the gauges. What would I need to do to get the speedometer and tachometer working. TheHolley will be controlling the transmission so I just need the signal to work the gauges.
Old Jan 18, 2020 | 11:47 PM
MikeGyver's Avatar
Default [quote=Lou99tahoe]
I am installing a Terminator X with Tranny control for a LS turbo swap in my 1999 2dr Tahoe, and want my gauges to work. I was thinking about splitting the Holley signal wires to work my factory gauges. The oil sensor I assume I can split. The coolant sensor, I read that 98 Camaro is a 3wire sensor that has 1 signal wire for the gauges. What would I need to do to get the speedometer and tachometer working. The Holley will be controlling the transmission so I just need the signal to work the gauges.
Old Jan 18, 2020 | 11:48 PM
MikeGyver's Avatar
I thought it would help if your words were visible
Old Jan 19, 2020 | 02:38 AM
RedXray's Avatar
100% Redneck
Can you run the factory ECM along with the Holley? The gauges on Matt's truck work using both.
Old Jan 19, 2020 | 08:58 AM
Lou99tahoe's Avatar
Yes that’s what I am planning to do I just don’t know what sensors I need to share for factory RPM MPH and AIr Condition to work on a GMT400 platform. What Matt’s doing is the newer platform
Old Feb 18, 2020 | 12:35 AM
Skeetrat's Avatar
How does ABS play into swap? Or does it
rjw
Not Manufacturer Specific Parts
Sep 5, 2016 01:49 PM
DrX
Aug 20, 2016 08:10 PM
#third
Jan 5, 2015 01:26 PM
nonnieselman
Nov 11, 2008 10:40 PM
caliking97
Jun 20, 2008 09:08 AM
