Need help with coolant temp sensor location
Old Jan 3, 2015 | 08:01 AM
Default Need help with coolant temp sensor location
I am doing a 5.3L Carb swap into my 1998 GMC 1500. The factory gauges have been replaced by auto meter units. My water temp gauge is just a signal wire setup. I see the cylinder heads have water temp sensor and water temp switch output connectors. Can I just put a adapter into the drivers head or should I use the one on the pass side head? Also if someone had a couple adapter part numbers that would be great!! Thanks
Old Jan 3, 2015 | 10:37 AM
George C....'s Avatar
Formerly ScreamingL
my jeep swap i have stock sensor in drivers head as that is required for the PCM
my gauge sensor is threaded into the pass side head
Old Jan 3, 2015 | 11:37 AM
Default Will this work?
http://www.ebay.com/itm/Auto-Meter-5284-Fitting-Install-Kit-/310946443830?pt=Motors_Car_Truck_Parts_Accessories&hash=item4865da3236&vxp=mtr
Auto Meter 5284 Fitting Install Kit
Fitting Install Kit
GM LS Engines
Includes 340° cylinder head temperature sender
LS Install Kit
Old Jan 5, 2015 | 12:39 PM
terravast4's Avatar
i have my set up just like screaming does
Old Jan 5, 2015 | 01:26 PM
Formerly ScreamingL
cant speak on that adatper as ive never used it
lucas287
31
Jan 12, 2021 06:18 AM
6.0l RST
Nov 23, 2015 11:30 AM
99bluefirebird
Sep 17, 2015 08:05 PM
ullose272
11
Jul 17, 2015 07:22 AM
