tbss intake and flex fuel inj's
Old Dec 21, 2008 | 12:47 PM
Default tbss intake and flex fuel inj's
ok so I have been working on this tune all day on hptuners and I cant get my afr's lower then 14.7 or so and I have my pe tables all the way up to 1.64 from 3000rpm up to 7200 whats wrong here. how do I upload my tune to this thread?
Old Dec 21, 2008 | 01:24 PM
here it goes
File Type: hpt
Old Dec 23, 2008 | 08:37 AM
mcfarlnd's Avatar
Un-Registered User
i cant see the tune right now at work but, what is your delay rpm at and tps enable for your pe. im assuming we are talking about wot tuning
Old Dec 23, 2008 | 07:31 PM
yes wot i got the idle fixed it was a sticky tb blade.
Old Dec 31, 2008 | 12:20 AM
mcfarlnd's Avatar
Un-Registered User
under your pe tab, zero out your delay rpm, if you have it set to 5500 your not gonna go into pe mode until a 5500 rpm delay is present. enable torque to 0%. also, raise your enrichment rate up to 4, some say after 2 they see no difference but,you want your pe to kick in as soon as possible. use your stock pe enrichment multiplier table and add 5% to the whole table to get started with it. log that and see what you get. add or subtract from that table to get your desired a/f ratio(higher the number the richer you get).
Old Jan 1, 2009 | 12:23 PM
thanks for the help all is fine now it feels like its alot stronger to since i got my afr up to 12.8 from 10.0
05GMC4.8
Aug 7, 2015 09:55 PM
RS/SS 4.8
Aug 2, 2015 11:03 PM
MWRitter
Jul 27, 2015 09:41 AM
04450r
Jul 24, 2015 01:58 AM
Closer_2001
Jul 21, 2015 03:25 PM
