Tach slightly off after v8 swap, can it be corrected with tune?
Old Jan 23, 2018 | 10:11 PM
Bencase's Avatar
Default Tach slightly off after v8 swap, can it be corrected with tune?
Ok so the IPC from a v6 truck Reads the cam sensor differently or gets a different signal from the v6 vs v8 if I’m correct. is there a way or place to change the way the vehicle reads this to correct rpm output on cluster in HP tuners?
Seems like it’s off with a multiplier so it gets exponentially worse the higher the RPM.
Thabks in advance
Old Jan 24, 2018 | 01:08 PM
terravast4's Avatar
maybe a tach adapter?
Old Jan 25, 2018 | 11:58 AM
2002_Z28_Six_Speed's Avatar
You could try using EFILIVE or HPTUNERS to swap the segments to the closest thing that matches your configuration. I bet that would fix it.
There are segments for the engine, system, speedo, fuel, and misc IIRC.
Old Jan 26, 2018 | 05:28 PM
Last Call's Avatar
TOTM: January 2007
I believe the cluster tach uses the PCM tach output, which can be configured in the tune. It is likely off because the output is configured for a 6 cylinder, and it needs to be 8. Should just need to change high and low pulses to 3 and 3. That will be an 8 cyl tach output.
Old Jan 27, 2018 | 07:44 AM
Bencase's Avatar
Thank you so much lastcall. My pulses were at 6 and 6 and changing them to 3 and 3 made the problem twice as bad. 8 and 8 was what made it dead on for my truck at least. Thank you for the tip.
Old Jan 28, 2018 | 11:49 PM
Last Call's Avatar
TOTM: January 2007
Cool, glad you got it figured out!
ZQ8 Blazer
Mar 22, 2017 04:04 PM
dmelvin
Jun 12, 2012 05:57 PM
moregrip
Jan 20, 2006 10:50 PM
white1
May 25, 2005 08:27 PM
v8
Jan 19, 2005 08:25 PM
