TAC Module
Old Nov 6, 2011 | 11:49 AM
Luke03's Avatar
Default TAC Module
Truck went into reduced engine power last night everytime i cleared the codes and restarted it. Battery power is good and cranks right over. Pulled codes P1516, P1518, and P2108. I checked the connections to the throttle body (was fine), the ground on the back of the pass. side cylinder head (was a little dirty and a little loose so it was tightened and cleaned as much as i could), checked the connections on the TAC module and the pedal. Let it idle for about 20 minutes and drove it around and did some WOT runs and couldn't get the code to come back.
With my wife driving the truck mostly right now so i can't have this kind of stuff happen right now. So hopefully i can get a used throttle body off of here.
My question is though can i use years 02,04-07 classic TAC modules or do i need to find a 2003 only TAC module?
Old Nov 6, 2011 | 01:19 PM
fastrt's Avatar
11 Second Truck Club
2003. I know my 06 is the only thing I can use. I know if I go to a 2005 operating syatem I have use a 05 tac and pedal.
Old Nov 7, 2011 | 12:34 PM
blackcash's Avatar
03-05 are the same. 06, 07Classic are the same.
Old Nov 7, 2011 | 02:21 PM
Luke03's Avatar
Thanks guys. I'm guessing all the pedals are the same too right?
Jordan927
Nov 10, 2015 02:47 AM
mitchellmade
Sep 27, 2015 08:27 PM
supershift67
Sep 18, 2015 08:21 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
cousblake11
Sep 9, 2015 06:52 PM
