Swapping BCMs to bypass Autoride
Old Jan 25, 2012 | 08:53 PM
PSI GUY's Avatar
Default Swapping BCMs to bypass Autoride
Hey, I've been searching around and can't seem to get a straight answer. Even the dealer techs haven't been helpful on this one. I don't have the Autoride components on my 03 Denali anymore, and having to clear the message on the information display every time I start the truck is super annoying. Is there anyway to swap a BCM from say a regular Yukon or Tahoe that would have the same options minus the Autoride to stop this annoying message in my display?
Old Jan 25, 2012 | 09:53 PM
Suburbazine's Avatar
I bet you swapped the shocks out and got ones without the damper control? Contact Arnott Industries and see if they will sell you some damper bypass units that splice into the shock harnesses.
I have had luck occasionally in pulling the fuses for components, unhooking the battery, then reconnecting the battery. Sometimes when the BCM scans for installed modules on power up it will mark dead devices as "not present" and stop throwing codes for them.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
creekrat
Aug 2, 2015 01:27 AM
therock
Jul 25, 2015 09:23 AM
Nimoryan
Jul 5, 2015 03:50 PM
