Stumbles on take off..if cold
Old Apr 4, 2007 | 10:25 PM
1SlowHoe's Avatar
Destroyer of Transmissions
More logging this morning. Better PID selection. Somebody figure this out. It's annoying.
File Type: efi
Old Apr 4, 2007 | 10:35 PM
dc_justin's Avatar
Hello Dave
Your commanded AFR is nearly 18:1 when it first goes lean ... Repost up that latest tune please!
Old Apr 4, 2007 | 10:38 PM
Rhino79's Avatar
9 Second Club
Which wideband is more accurate?? You have 2 selected and also you are commanding really lean AFR. I would richen the values in the Commanded Fuel when in Open loop table a good bit ( maybe around 14:1) and try that.
1SlowHoe's Avatar
I KNOW
It's readin 19.86:1 with 0 spark.
File Type: tun
Rhino79's Avatar
9 Second Club
Damn Justin, you beat me to it.......
Old Apr 4, 2007 | 10:41 PM
1SlowHoe's Avatar
That PID list is one that DC-Justin sent me awhile back. I don't know why it has 2 different LC-1 readings. The one that sits at 13:1 or so at start up is in sync with the gauge in my pod.
AFR_LC12 Wideband AFR 2-LC-1 is the correct one.
dc_justin's Avatar
Hello Dave
That's the table I had him replace... and it really looks as if he is viewing it in Lambda instead of EQ. It should be commanding 13.x:1 there, not 18...
1slowhoe... Try this one uploaded. I took for granted that you were viewing in the default units... I shouldn't have.
File Type: tun
Old Apr 4, 2007 | 10:43 PM
dc_justin's Avatar
Hello Dave
Yeah, had you select both of them cause I didn't know which External input you had it plugged into
Old Apr 4, 2007 | 10:46 PM
1SlowHoe's Avatar
I am still very green at using EFI. I have trouble with the basics like switching between metric and imperial. lol. I don't know how to switch from lambda to EQ or even what EQ is.
I will upload your file and let you know tomorrow what it did, and log it.
Thanks,
Old Apr 4, 2007 | 10:47 PM
1SlowHoe's Avatar
Ohh, I see. Well, If I knew how to remove it I would HA!
When is the EFI class coming to Pensacola? (hint)
