strange problem...
Old Dec 3, 2008 | 11:15 AM
Noah Burns's Avatar
Default strange problem...
ok, so i put the stock tune back in my truck last weekend... on certain days when i start the truck and leave the house I can go WOT and it will turn ~4000 rpm and mph will very slowly climb, this will happen a few times... if i pull over, turn the thing of let it set a second and then restart it, it will stop and run normal, wot and it will haul *****... anyone ever had any experience like this?
Old Dec 3, 2008 | 12:45 PM
KLUG'S SS's Avatar
FormerVendor
I recently did a tune on an 08 GMC and this sounds like one of the rev limiter tables. On the 08 I tuned he was having similar issues especially when he first would start up and take off and I had to up his rev limiter because we raised his shift points and it went away.
Can you post your tune? If so I could show you where the problem is more than likely.
This may not be your problem but it does sound similar to what I was seeing before on an 08.
Old Dec 3, 2008 | 12:52 PM
KLUG'S SS's Avatar
FormerVendor
You can do a scan and log the run when it's doing it and see if anything looks out of place.
Old Dec 3, 2008 | 01:03 PM
Noah Burns's Avatar
problem is i put the stock tune back in it and its doing it even more now... I will post the tune and a scan though (isn't a scan of when it was doing this)
Old Dec 4, 2008 | 02:29 AM
Noah Burns's Avatar
i THINK... this is the scan from when it happened last time... not 100% positive on that though.
File Type: hpl
91LT16SpeedFormula
Oct 17, 2015 08:01 PM
97_ek
Sep 23, 2015 09:16 PM
GMCtrk
Sep 11, 2015 09:04 AM
BennyB
Aug 1, 2015 08:48 AM
