Still lean?..
Old Oct 4, 2008 | 11:49 PM
Question Still lean?..
So my 03 Suburban was throwing a lean condition bank 1 and 2 ... The rig would every so often have a random misfire at idle, that would clear up rather quickly. The misfires come few and far between and ONLY happen at idle..the truck rips otherwise... Usually runs flawlessly.
I cleaned the MAF, I have changed the intake gaskets. Still getting the lean condition on both banks. Any advice?...
Old Oct 5, 2008 | 07:50 AM
Grumpy5.3's Avatar
did you install the teal green intake gasket??? I have had to replace a few intakes because the sealing flange is warped!!! take some intake cleaner or brake clean and spray around the entire sealing area for the intake tothe heads. you should hear a change in tone of the motor...
Old Oct 6, 2008 | 12:16 AM
Yea teal ones, I've done the carb spray check too. Not one lil burp in RPM change. I am sure it sealed up.
Old Oct 6, 2008 | 12:37 AM
Wilde Racing's Avatar
How do I change this text
To find an intake leak spray starting fluid (carb clean, wd-40) around the intake, if it revs up, there is your leak... ***IT IS HOWEVER, VERY DANGOURS. IF THERE ARE ANY SPARKS FROM SAY A SPARK PLUG WIRE, THE END RESULTS ARE NOT GOOD**** the best way is a smoke machine, but I've sued starting fluid with success...
Any other work done to the Suburban lately?
madmann26
Apr 29, 2020 09:17 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
03sierraslt
14
Oct 9, 2015 05:53 AM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
Chevy305
Sep 28, 2015 09:21 PM
