Startup Tune for the Project Truck
Old Nov 20, 2007 | 07:12 PM
  #81
03sierraslt's Avatar
Any progress?
Old Nov 20, 2007 | 08:10 PM
  #82
Holty's Avatar
Notorious BIG
I was afraid of that, moregrip- as many people that have used these injectors I would think there would be some solid info floating around somewhere the only problem is determining what is actually correct... I have found many, many different settings that people say work but what is actually correct I am still trying to determine.
Mine idles at 14.5-14.8 and cruise is about the same, WO is also spot on.. However I do have a rich decel. Decel is not as rich as it was when I first started messing with them but its still rich. I could always go back CLSD but.... Thats the easy way.
CLSD will not fix the rich decel, trust me....
last i heard from justin, he was working on a fix (efi live only though).
Old Nov 20, 2007 | 09:42 PM
  #83
I didnt suspect it would competely but i figured it would help some, No?
Josh I have been trying to get ahold of your ***.
Old Nov 20, 2007 | 09:44 PM
  #84
dc_justin's Avatar
Hello Dave
CLSD should fix that rich decel... If it isn't for you, check your minimum pulse width tables.
Old Nov 22, 2007 | 09:58 PM
  #85
So whats a good min pulse for these injectors?
Old Nov 23, 2007 | 09:15 AM
  #86
dc_justin's Avatar
Hello Dave
Lower than the PW + Injector voltage offset that gives you a rich decel
Old Nov 23, 2007 | 08:35 PM
  #87
Well, I figured that.. Mine seem to start misfiring and it goes lean If I try to get the pulse lower then it is under current decel. 1.5 is as low as it goes right now.
Old May 2, 2008 | 12:10 AM
  #88
moregrip's Avatar
what a rush!
it's been a while............my computer took a dump a while back and I'm back to ground zero, I need to work on this in my spare time, but like fast!
03sierraslt...........help!
ARC
57
Feb 21, 2022 10:54 AM
SLOPONY
20
Oct 18, 2016 06:05 AM
wrb002
Aug 31, 2015 12:00 PM
Austino
Jul 30, 2015 03:28 PM
black6spdz
Jul 16, 2015 01:32 AM
