Start engages when connecting battery
Old Aug 6, 2011 | 12:15 PM
TXjeepTJ's Avatar
Default Start engages when connecting battery
I took the starter off and reinstalled in, I think I connected it correctly but now when I connect the battery the starter engages and does stop until I disconnect the batter, any thoughts?
Old Aug 6, 2011 | 12:30 PM
99LsSilverado's Avatar
The first thing to check is to make sure the signal wire (the small one on the starter) is not touching the main power wire (the big one). I had the same issue when I changed my starter last year.
Old Aug 6, 2011 | 02:38 PM
TXjeepTJ's Avatar
good point, I'll check that out- thanks!
Old Aug 7, 2011 | 12:20 AM
TXjeepTJ's Avatar
You nailed it, there is a tab on the main + to the starter that was touching the signal wire
thanks!
Old Aug 7, 2011 | 12:51 PM
Your welcome. Like I had said it happened to me when I changed my starter after work one night about 130am. Just got to watch the wires and there placement.
Old Aug 7, 2011 | 03:43 PM
oldred95's Avatar
thanks!
Don't you hate it when that happens. I did the same thing once but kept my composer and checked and sure enough that tab was touching the small wire.
treylittlefield
Jan 24, 2016 07:38 PM
Suburbazine
Aug 9, 2015 01:17 AM
Ferocity02
Aug 7, 2015 08:50 PM
atxlt
Jul 20, 2015 11:06 PM
