Stall won't lock up.
Old May 15, 2016 | 05:51 AM
madmann26's Avatar
Originally Posted by Furdkiller
Took it to my tuner, he used his computer to manuelly shift the truck and the truck still wouldn't lock up. Then on wot it began to slip. I hope these guys didn't do me dirty. He gave me a 6 month warranty so I'm taking it back on Monday.
Damn. I hope they do you right. FWIW, my RPM transmission has been bullet proof. No issues with it.
They have more "economical" transmissions if you happen to need another one.
Old May 17, 2016 | 08:46 AM
Furdkiller's Avatar
I picked the truck yesterday and the truck goes from 1-2 around 10 mph, 2-3 around 20 mph, and 3-4 around 30 mph. Now the stall locking up would be considered another gear right?
Old May 17, 2016 | 09:15 AM
Wolftrk99's Avatar
That a lot of quick early shifting youve got going on there!!!
Old May 17, 2016 | 09:38 AM
Furdkiller's Avatar
That's on cruising speed lol not wot
Old May 17, 2016 | 09:44 AM
Furdkiller's Avatar
Wot is 1-2 around 45 it's spinning so idk haha then 2-3 at 80.
Old May 17, 2016 | 10:45 AM
Wolftrk99's Avatar
Ok, that sounds better, dealing with a 26mph 1-2 shift and a 2-3 shortly thereafter on my truck now... Has to be in tune, started when i swapped the converter to a tb converter a few months ago and its carried on into this new trans, so..... Frustrating as hell!!!
Old May 17, 2016 | 12:38 PM
Furdkiller's Avatar
When the stall locks up it's another gear right? I use to feel another gear kick in at 45 mph before the transmission rebuild, but now I don't feel it. Is the stall not locking up after 4th gear?
Old May 17, 2016 | 12:51 PM
FFDP's Avatar
It's not another gear, there are only 4 speeds.
The rpm in 4th gear will drop 100-200rpm or so once it's in lock up.
You can watch it with a scanner to make sure it's in lockup.
Old May 17, 2016 | 12:56 PM
Furdkiller's Avatar
I need to buy a scanner. Any recommendations ?
Old May 17, 2016 | 01:01 PM
FFDP's Avatar
You already said you went to your tuner and it wouldn't drop into lock-up, no real point in you having to spend more money on a scan tool to figure out the same information.
