sputter above 4k at wot or 3/4 still have 60 psi fuel please help
Old Apr 30, 2014 | 12:22 AM
cammd5.3's Avatar
Registered User
Default sputter above 4k at wot or 3/4 still have 60 psi fuel please help
Ok 05 silvy 224 cam pav 600 springs hard end pushrods Lt midpipe. Nelson 93 tune cai Ok guys I cleaned the maf and TB and use new ngk plugs gapped to .060, fuel pressure check it held 60 psi during wot and never dropped . Hasn't thrown any codes or misfires, idles fine and drive perfect but if I get to 4k it start sputtering it's driving me crazy started doing it after I pulled my nx kit off also but fuel Shrader valve don't leak or suck air that's all I touched
Old Apr 30, 2014 | 12:35 AM
1FastBrick's Avatar
Custm2500's Rude Friend
Factory Spark Plug Spec changed to .040 when they went from factory installed platinum to replacement iridium.
If you have NGK iridium they should be .040
Old Apr 30, 2014 | 12:41 AM
cammd5.3's Avatar
Registered User
There ngk tr55 and the ngk I pulled out were the same gapped at 35 and still didn't change it acts the same
Old Apr 30, 2014 | 12:44 AM
1FastBrick's Avatar
.035 is probably about right on that plug.
What about plug wires? ever changed them???
Are you sure there seated all the way on both the coil and the plug???
Old Apr 30, 2014 | 12:53 AM
cammd5.3's Avatar
Registered User
Msd wires and yeah I'm pretty positive it idles fine with no arcing or rough idle spots and drives fine and pulls smooth under regular driving
Old Apr 30, 2014 | 04:07 AM
Noah Burns's Avatar
have you checked the plugs since this started happening? sounds like they may be your issue.
you mentioned nitrous... that could have something to do with it too
Old Apr 30, 2014 | 03:13 PM
cammd5.3's Avatar
Registered User
Well my plugs were fine but 3 and 5 were white powder when I change them but I didn't pull the new ones out yet
Old Apr 30, 2014 | 06:26 PM
Noah Burns's Avatar
I had a similar issue the first cam swap I did, the plugs were fouled/busted tips... changed to some TR55s and cleared it right up.
Old May 1, 2014 | 08:15 AM
cammd5.3's Avatar
Registered User
Could I have a bad coil or clogged injector? And it don't make sense how it won't miss or anything driving till I hit 4k. And in park it will rev up to whatever and be smooth so it's only when the engine has a load on it
GXPJAY
Feb 13, 2022 08:15 AM
ss4chad
Aug 15, 2015 02:25 AM
noproblems209
Aug 10, 2015 06:57 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
