Spark issue "off the line"
Old Nov 17, 2009 | 05:57 PM
12sec.5.3's Avatar
Default Spark issue "off the line"
Made a few logs at the track and noticed a spark issue that i may need some help with. First the stall is a 3600-3800 circle D. Stalling about 1500rpm staged up timing is ~40* then when taking off the spark goes down to 14.5* then back up to 26.5* at around 4100rpm and remains wt commanded for the rest of the run. I commanded the specified cells in my spark table to 35* and now get somewhere around 21*. Don't know why its dropping for this short amount of time but i need to correct it. Any ideas of wt can be checked?
Old Nov 17, 2009 | 06:05 PM
BlackGMC's Avatar
Resident Retard
post up your log... and tune....
Old Nov 18, 2009 | 01:40 AM
Wilde Racing's Avatar
How do I change this text
Log "Burst knock" see how much it is pulling...
Old Nov 19, 2009 | 07:02 PM
krambo's Avatar
More than likely that is your answer. Also, confirm you are using the HI octane timing table...
Old Nov 19, 2009 | 07:20 PM
12sec.5.3's Avatar
I copied the high oct spark table to the low oct table so it should be commanded.
Old Nov 19, 2009 | 08:07 PM
fastgmc53's Avatar
14 Second Truck Club
also make sure your TQ management is disabled because it will pull timing also..
Old Nov 19, 2009 | 10:20 PM
SRT10KLLR's Avatar
Former Vendor
Mine does the exact same thing. It is actually a good thing for me as it spins a lot. It is my built-in traction control, lol. Someone here asked about pulling timing for launch control well here it is.
Attached are some logs of some runs I made at the track.
The first one I was peddling it because I lost traction off the line. You can see that every time I stab the peddle the spark goes way down sometimes negative. It is almost a mirror opposite of the throttle.
The second and third runs you can see I tried launching at 50% throttle to get traction.
I also need to get a IAT relocation adapter because my IAT's are always really high do to heat soak and that pulls timing also.
File Type: efi
File Type: efi
File Type: efi
File Type: efi
Old Nov 20, 2009 | 07:50 PM
three83's Avatar
My truck was pulling timing at launch and the only way we were able to stop this was to disable all Torque Management.
A customer at a friends shop, 08 Silverado Ex Cab 4x4, built 5.7L w/turbo. They had a problem with it pulling timing, turned out to be a knock sensor.
Old Nov 21, 2009 | 12:42 AM
No, there are many other tables that factor into timing. The high and low tables are just kind of a "base" table, (actually base idle is), Anyways, point is, you have multiple tables the affect actual timing no matter what you put in the hi/low tables. Torque management is another good place to check, but from what you are describing, I'd be sure and log "burst knock" aswell...
Feel free to post up a tune file
Old Nov 21, 2009 | 07:30 AM
KLUG'S SS's Avatar
FormerVendor
This sounds very much like Burst Knock and an easy problem to fix. It can be tuned out though so I would highly suggest that you dont just go and zero out the burst knock table because that is kind of a lazy "half ***" way of taking care of it IMO and because burst knock does serve it's purpose in the tune.
