softening DFCO enable
Old Jul 30, 2010 | 10:40 AM
BlackGMC's Avatar
Resident Retard
Default softening DFCO enable
I was playing around with the DFCO settings yesterday, apparently it has never worked on my truck.. Anyways i got it working but when it enables it is very noticeable, almost like someone put on the brakes.... Is there anyway to soften it or make it less noticeable when it engages? Ramp in rate or would raising the commanded timing help? Currently my ramp in rate is 0.07 and timing is 5*....
thanks in advance...
Old Jul 30, 2010 | 11:38 AM
MikeGyver's Avatar
I can't find in HP Tuners. I don't know, but seems to be the same as what sucks about our rev limiter, when the fuel is cut off, it is cut off.
Old Jul 30, 2010 | 12:35 PM
Atomic's Avatar
I have a gauge for that
Make the threshold to engage at a higher MAP. If you are pulling a lot of vacuum when it engages, it will be very noticeable since the braking effect is greatest.
Old Jul 30, 2010 | 12:40 PM
BlackGMC's Avatar
Resident Retard
so make it come on sooner?
Old Jul 30, 2010 | 12:50 PM
hirdlej's Avatar
Personally Corey I've never seen a noticeable difference having it enabled other than the severe "braking" effect. I disabled mine and never looked back. When you go off throttle and back onto the throttle I never liked the jerk or lash that the DFCO caused. It's much easier on your drivetrain to leave it disabled.
Avalanche2002
Nov 30, 2015 07:31 AM
lxcoupe
17
Aug 26, 2015 05:00 PM
Closer_2001
Jul 21, 2015 03:25 PM
KySilverado
42
Nov 24, 2006 10:45 AM
