Should I get a new PCM??
Old Aug 18, 2005 | 07:16 PM
greentahoe's Avatar
Default Should I get a new PCM??
Ive got the 01 PCM in my tahoe, but Im putting a LS2 402 in and I was thinking that I may start a little closer to what Im going to need by starting with an 02 (they still have the cable actuated throttle right?) 6.0 pcm and file. Will this be of benefit or should I just modify my existing file??
Old Aug 18, 2005 | 08:05 PM
TG02Z71's Avatar
From what I've seen here the 02 PCM is the better of the two.
My 2002 5.3l has a cable throttle as well.
I would think the 4.8l and 6.0l would have too.
Old Aug 22, 2005 | 11:01 AM
gonzo 6.2's Avatar
I understand the 01-02 are the same PCMs
Old Aug 22, 2005 | 09:14 PM
dewmanshu's Avatar
Moderately Differentiated
supposedly there were a few (programming) differences in the 01 and 02...but maybe nothing your upgrades would care about. But FWW my 2000 5.3 pcm to 2002 6.0 pcm swap was cable driven.
Tahoe...5.3? I never liked the idea of changing everything to be a 6.0 in the pcm if it was originally a 5.3 pcm, like copy and pasting. if the Tahoe is 6.0 I'd stick with your pcm unless you can get the 02 easily and cheap or one of the tuners chime in speaking of some huge difference, like the 01 is much more acceptable to knock retard or something...hehehehehe my 2 cents
Old Aug 23, 2005 | 10:03 PM
greentahoe's Avatar
I wish Tahoes had 6.0 to start. Im going to start with a stock 6.0 file and go from there. Tuning the VE will be horrbile Im sure but I should be able to nail down PE and AFR pretty quickly.
Wrecker 426
Sep 30, 2015 09:39 PM
Velocity1
Sep 22, 2015 01:32 PM
kalikid06
Sep 20, 2015 07:46 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
