shift ponits by MPH instead of RPM
anyone with a GM 6L80 (preferably a 6.2 with 3.42 gears) tune their WOT shift points based on mph instead of rpm? If so, what speeds did you use in each gear? And what rpm did that correspond to?
I'm using Diablosport In-Tune. 2014 Sierra 6.2. For some reason, when I set WOT shift points with rpm in the 6200 range, it does not like it. It stops pulling before reaching the set point - shifts - then picks back up. Also tried raising the rev limit to make sure that was not the problem. Lew recommends setting the shift points based on speed instead of rpm. So we'll give that a try. I'll have to go out this weekend and data log it. 1st, 2nd, and 3rd are the most important to dial in. I don't have a good place to get WOT shifts for 4th and 5th without chancing a long conversation with D'man.
did some data logging in case anyone else needs the same info.
2014 GMC Sierra, 6.2 with 3.42's with factory 20" wheels. My desired WOT shift points for optimal 1/4 mile or 0-100 mph:
1st 6200 rpm = 41 mph
2nd 6100 rpm = 69 mph
3rd 6100 rpm = 107 mph
4th 6000 rpm = ? didn't go that fast.
5th 6000 rpm = ?
5th 6000 rpm = ?
LCHEE
Oct 24, 2020 04:10 PM
