Shift Firmness By Tune Or In the Tranny
I just had a 4L60e built up to 4l65e specs with the 5 gear planetary sets and all the other goodies, a trans-go kit, 2-4 performer band, better sun shell, better servos and a few other mods.
He told me to run it a while and if I wanted it firmer to bring it back.
Well I do want it a tad firmer, and I have a Radix on the superchips tune and plan to replace that with a dyno tune in Ls1 edit or HPtuners. I'll be dropping a pulley size and hoping to close in on 400 RWHP.
Should I bother with taking it back to the shop and let the tuner firm it up?
And with the better tranny how much TM would you leave in?
Thanks
Thanks
Thats all up to you man.. if its a built transmission id take all the TM out.
If it shifts too harsh you can put a small percentage back in to soften the shifts.
How many # boost your running now?
I'm going to a 3.4" and a Dyno tune. What do you think? Will a bit smaller pulley and a superior tune get me from 366 into the 390 RWHP numbers?
So what do I need to do to straighten this out correctly? I want the current tranny firmer.
Assuming the "better servos" are Corvette 1/2 and Billet 3/4. you should remove the Tq Management and see how you like it. Once it's all gone if you still want it firmer you can have it firmed up in the tune or the shift kit. Shift kit being preferred.
You don't want to be barking the tires while driving around cruising. That's bad for it.
