SES Code P0171, and P0300, Help Please
Hey guys,
So my truck is throwing these codes
P0171 - Fuel Trim System Lean Bank 1, is what it is saying for this code
P0300 - Random/Multiple Cylinder Misfire Detected
Any help with what this may be, im kinda leaning towards the MAF, also how do you get rid of a truck running lean,
Truck is an 02 GMC, intake, exhaust, and tune, thanks
Hey guys,
The truck runs fine on the freeway. At idle it does stumble a bit and when I drive it at low in town driving speeds it falls on it face when I go to give it a little gas. If i jump on it from a dead stop it will cut out and back fire. Like it loads up then it takes off then stumbles again. WTF. If i ease into the gas it runs fine? So i have to ***** foot my truck to drive it and it is driving me nuts. I"m gonna do an oil change, re-place fuel filter, clean mass air, clean throttle body today. It needs to be done anyway but I have to rule a couple thins out first. I will also check for any vaccum leaks too.
I'm with you. Intake gaskets could be leaking, fuel pressure low, or lazy o2 sensor only showing 100mv with cause ECM to continue to add fuel and get Bank1 so loaded it will misfire on 1,3,5,7.
