service light
Old Oct 12, 2009 | 11:27 PM
bad intentions's Avatar
Default service light
guys today i changed out my volant filter for a K&N and after a drive from work to home my service light came on. the reason i switched was to allow more air flow. now my truck is tuned could this just be a need for a retune with this new filter?
Old Oct 13, 2009 | 12:26 AM
viciousknid's Avatar
Where's the Beef?
too much oil on the filter. the oil is getting on the MAF sensor. Dry the filter a little and clean the MAF sensor with some brake cleaner.
Old Oct 13, 2009 | 01:12 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Have you scanned for DTC's yet? Post up your codes.
First thing you need to do is recheck your installation for loose clamps/boots, etc. Wouldn't hurt to clean the MAF at the same time.
Old Oct 13, 2009 | 07:22 AM
the filter was brand new it had no wet oil. does the brake cleaner work on the 09 as well.
Old Oct 13, 2009 | 10:54 AM
Don't use brake cleaner on your MAF. There are several brands of MAF cleaner available at your local parts store.
Old Oct 13, 2009 | 11:29 AM
ok codes that appeared r p0175 n p0172 to rich
Old Oct 13, 2009 | 11:35 AM
Was the check engine light on before you changed air filters?
Old Oct 13, 2009 | 11:40 AM
no i switched on a couple hours later
Old Oct 13, 2009 | 11:44 AM
Sounds like unmetered air entering the engine. Computer goes pig-rich to try to keep the engine running, sets a code. Did you recheck your installation?
Also, lose the TB spacer.
Old Oct 13, 2009 | 11:51 AM
i had on a thick volant air filter that changed cause thought it restricted flow n now i get this everything is on good
