Service Charging System ... findings
Old Feb 24, 2016 | 09:41 AM
Mean Green z28's Avatar
11 Second Club
Default Service Charging System ... findings
So my truck flashes the service charging system message and also turns on the idiot light when first started and then some times goes away after a while. Alternator is new-ish and the Battery is brand new. The Volt meter on the dash shows it's charging above 14.5V approx, but when I hook up my DashLogic and looked at the Volts, it's around 13.5V ... I'm assuming the BCM looks at the value that the DashLogic shows.
So, do I try and replace the alternator under warranty? Get it checked out? I've heard this is a common issue with the charging system message, what have others done?
Old Feb 24, 2016 | 10:38 PM
1FastBrick's Avatar
Custm2500's Rude Friend
In my case I had to replace the alternator.
Old Apr 10, 2016 | 10:09 AM
11 Second Club
May have to get a warranty claim
Old Apr 11, 2016 | 06:23 PM
1FastBrick's Avatar
Still having issues?
Old Nov 3, 2016 | 08:54 PM
11 Second Club
thought I'd put this to rest. After swapping batteries and also alternator under warranty, it turns out that the previous tech added about 6" of wire to the alternator signal wires .. well I guess his skills were a bit short ... I needed to shorten them because I ran the harness different, so I cut out the splice that seemed to be soldered on, and used new fresh wires for the shorter splice and made sure I made a clean solder joint and shrink tube'd etc. ... NO MORE MESSAGES!
Old Nov 3, 2016 | 09:43 PM
1FastBrick's Avatar
Glad you got it fixed!
Thanks for posting your findings.
truefire04
Apr 2, 2017 09:41 AM
Slow91z
20
Feb 15, 2016 03:51 PM
bisqikss
Feb 4, 2016 10:21 PM
