Service Airbag light???????
Old Nov 21, 2012 | 04:49 PM
Maf6.2's Avatar
Registered User
Default Service Airbag light???????
Left work yesterday and had a "service airbag" message and the airbag light was on. Got home and checked it with my AutoCal but no codes came up. Disconnected battery for a bit and re-connected it and message was still there. This morning when I was leaving for work, it was gone! Any ideas?????? I definately dont want to deal with the dealer if i dont have to...
Old Nov 21, 2012 | 07:28 PM
1FastBrick's Avatar
Custm2500's Rude Friend
With out the ability to read the code you will never know.
Old Nov 25, 2012 | 07:58 PM
BetMinesFaster's Avatar
Down and out
2 common problems for that truck.
1 is front impact sensors located on bottom of core support.
2nd is the sensing diagnostic module (SRS module)
You will need to have somebody get a good code out of it to know where to start.
SDM's seem more common the salty states from my experience. Sensors are about 150.00 ea. at the dealer. They are avail. from Dorman. Crappy china parts, but with a lifetime warranty. And about 30-40 cheaper. SDM is a dealer part and requires programming from tech-2 or equiv.
Get a good code and ill walk you through the proper diagnostics to verify what part is failing.
Ryan
Old Nov 25, 2012 | 08:02 PM
RS/SS 4.8's Avatar
10 Second Truck Club
So that code that tells me its one of the two front impact sensors is common? My airbag lights been on for like 15000 miles
Old Nov 25, 2012 | 10:29 PM
Down and out
Yup....that's common! Lol
Old Nov 27, 2012 | 06:54 AM
Maf6.2's Avatar
Registered User
Back on again!! Still not reading any codes though. Can anybody tell me where all these sensors are located? Pics? Thanks in advance for the help...
Old Nov 27, 2012 | 08:55 AM
fortplainman's Avatar
about every year i have to replace a sensor regardless if it is the left or right side. get ready to cough up about 300 bucks.
Old Nov 27, 2012 | 12:48 PM
1FastBrick's Avatar
What are you trying to read the code with??? The SRS air bag system is separate from engine and transmission. Not all code readers are designed to pick up trouble codes from other modules.
You need something that is capable of reading codes from all module's. Like the factory GM Tech 2 or a Snap On scanner. There are some lower end Scan tools that are more affordable in the $100-$300 range that also have that capability like Autoenginuity, Autel, Maxdiag, OTC
With out a code, Your not going to know were to look. You can replace all the sensors you want. The problem may be within the wiring/connection or the module it self.
Idryfly5
Sep 2, 2022 08:55 PM
thompson
Dec 27, 2017 06:48 AM
Pimpinpete
43
Dec 22, 2017 08:13 AM
RustyD
May 23, 2016 07:04 PM
Closer_2001
Sep 24, 2015 09:15 PM
