Service 4wd
Old Dec 14, 2006 | 06:30 PM
98hardtopZ's Avatar
Default Service 4wd
this appeared a few hours ago as i put my truck into park and went to turn it off. 5 minutes later i cut it back on and it never came back? i went to park again, nothing. was it a just a fluke or do i need to go to dealer?
Old Dec 14, 2006 | 06:53 PM
CHEVRACER83's Avatar
Very common.... could be the 4wd switch going out.... happens alot. if it happens again.... replace the switch
Old Dec 14, 2006 | 07:00 PM
gao8302's Avatar
I had to have mine replace already. Just have it replaced and be done with it. I wont hurt anything if you drive with it on because i left mine on of a few weeks and then replaced it. I bet it scared you to see that light come on like it did me the first time.
Old Dec 14, 2006 | 07:09 PM
98hardtopZ's Avatar
which switch? the one left of the insturment panel?
Old Dec 14, 2006 | 07:12 PM
Yeah The One That Controls 4wd..... Thats All One Piece
Old Dec 14, 2006 | 07:14 PM
Do not drive around with the light on.... the switches break internally... and weve had a few that kept forcing back and forth between 4wd low and 2wd hi.... it pretty much grenaded the tcase.... I work for gm... I have seen it a few times.... its better to just change it
Old Dec 14, 2006 | 07:22 PM
98hardtopZ's Avatar
the message hasnt appeared since?
Old Dec 14, 2006 | 07:25 PM
Still The Switch Isnt Taht Expensive... Its Probably Good Insurance To Just Get It....
Plus The New One Is Made Betetr Than The Original
Old Dec 14, 2006 | 08:05 PM
Grumpy5.3's Avatar
on an 03 you may need a sensor inside the encoder motor, check the code and see what it is!!!
Old Dec 14, 2006 | 08:21 PM
blake2kz71's Avatar
sorry got a quick question, i dont have 4.10's in the front like i do in the back so i just pulled the fuse for my 4wd switch. surely this is safe. my service 4wd light stays on
