self-tuners...
Old Dec 12, 2005 | 09:16 PM
  #21
fullthrottledan's Avatar
im at 18 on 18 (degrees, boost)
Old Dec 12, 2005 | 09:38 PM
  #22
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
31* even spraying 100 shot on the old 5.3 dont know what it will be on the new motor
Old Dec 12, 2005 | 10:07 PM
  #23
Wink
Just it at 60*!! I wanna see that motor all over the track.
We'll see it that way sooner or later.
Jim
Old Dec 15, 2005 | 02:02 PM
  #24
dc_justin's Avatar
Hello Dave
Originally Posted by Holty
at 4400 RPM .76 g/cyl i'm running 21* on a Radix 6.0L
Right around where I'm at on that cell... but you'll hit much higher airmass than .76 with a radix...
My WOT timing runs from 15.2 at 2200rpms up to 18.5 from 3600-4800rpms and then drops to 17.5 above that. I'll get at most .5* KR in the 2000-2400 range at WOT
Old Dec 15, 2005 | 08:32 PM
  #25
Flyer's Avatar
.76 will be around WOT throttle NA. The gms/cyl is a calculated number derived from the MAF flow and RPM. I know in HPTuners there is a PID especially for that. I'm pretty confident EFILive had the same PID as well.
All timing is done by RPM and gms/cyl. gms/cyl is essentially how much air is in a single cylinder. Knowing this and the rpm, you can know exactly what kind of load is on the engine.
Old Dec 16, 2005 | 12:38 AM
  #26
01Blackerado's Avatar
Im seeing .87 g/cyl @WOT with 30.2 degrees at max!! I would work on your VE tables first before you do any changes to your spark tables!!!! You want to make sure your fuel corrections are as close to zero as possible!!!!! Reason being... your OBD2 sensoring does not get used by the PCM in WOT to make the proper corrections!!! Meaning your o2 sensors and MAF do not get used by the PCM once your in PE mode( Power Enrichment AKA WOT). It automatically uses the VE table for all its calculations!!! If your VE tables is sending wild fuel corrections right now, in ex: LTFT reading +3 or higher, or -4 or lower, than you could really be messing things up right now!!!! If you notice your scanner, AS SOON AS YOU GO WOT, YOUR PCM 0's OUT THE LTFT(Long Term Fuel Trims). If they are supposed to be making corrections that are higher than that 3% or lower than that -3% than when it 0's them out...you could be looking at a nice detonation from either lack of fuel, or air!! Usually lack of fuel is what you have to worry about though!!
Old Dec 16, 2005 | 01:04 AM
  #27
1slow01Z71's Avatar
Jim
Nope actually that was in 85* weather
Old Dec 16, 2005 | 11:22 PM
  #28
chrisj6's Avatar
damn anything 30-31* shoudl be MAX, you guys are running some damn high timing over that. Most LS-based engines run best on 27-29* WOT. Mine happens to be at 28-29*. And thats max as shown on the scanner, check your AFR adder, i had to back it out some b/c i was commanding 24* and getting 30*.
Old Dec 17, 2005 | 08:22 AM
  #29
02sierraz71_5.3's Avatar
Everyday its at 24 wot I see .88 g/cyl
at the track I run from 26-28
this is on 93 octane with 10.5:1 compression
