School me on ABS and Stabilitac dash lights
Old Sep 29, 2011 | 09:52 PM
outlaw38's Avatar
Default School me on ABS and Stabilitac dash lights
My ABS and stabilitrac light is staying on. How do you go about clearing these things. These lights are driving me crazy. Truck is a 11 Chevy 1/2 ton. I swapped gears and added a tru-trac. I would love to do away with the abs and stabilitrac if possible. I have already disconnected the battery and tried to reset by no luck.
Old Sep 29, 2011 | 10:37 PM
Pollo432's Avatar
Have you ran a scanner to see if it brings up any codes??
Old Sep 29, 2011 | 10:41 PM
outlaw38's Avatar
No codes
Old Sep 29, 2011 | 11:11 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If the lights are on, there are codes. Your scanner may not be scanning the correct modules.
Old Sep 29, 2011 | 11:12 PM
gavin2005's Avatar
Originally Posted by outlaw38
No codes
theres got to be codes if lights are on.they won't be in the pcm.you got to check abs codes.i regular code reader won't check them.you got to check them with a good scantool like the tech 2 or snap on verus
Old Sep 29, 2011 | 11:57 PM
outlaw38's Avatar
Those things are 10k. I'll put tape over the lights for that.
Old Sep 30, 2011 | 02:27 PM
Pollo432's Avatar
You don't have to buy the scanner. Take it to a mechanic he should charge u near nothing to scan it. Then u can go from their.
Old Sep 30, 2011 | 02:53 PM
89LS1FOXER's Avatar
Have some one pull the chassis codes for you and i can help ya, im a GM tech, just pm the codes and we'll go from there!
Old Oct 1, 2011 | 04:11 PM
outlaw38's Avatar
Thank you I will take it in and have it scanned.
Old Oct 2, 2011 | 11:07 PM
Suburbazine's Avatar
Since you have Stabilitrak I think you will need it recalibrated for the rear gears. I think it compares the speed sensor on the transmission to the wheel speed sensors; the new gears may be throwing it off.
