Schematics, Pinoouts, Training Materials, Technical Documents
Old Jun 4, 2012 | 03:18 PM
  #71
turboal1's Avatar
Default pin out
I need the pin out for a E67 PCM on a 2010 Colorado 3LT 5.3, I want to install an e-fan and need to know witch pin out i need to use to set
the on/off temp settings.
thanks in advance. turboal@aol.com
Old Jul 23, 2012 | 09:35 AM
  #72
KC_kid's Avatar
Default Approach & Exit lighting
This may be the wrong section but I'm throwing it out here..
I'm looking for a circuit I can tap that is tied into the approach or exit lights so I can get the puddle lights on my mirrors to operate with the other approach and exit lights. I have a 2011 LT and I'm hard wiring the power fold and puddle lights because I don't have door modules.
Currently, my plan is to tie into the "DOMELIGHT SUPERVISION GRAY (+) @ BCM, (WHITE Plug) Pin 5" but I wasn't sure if that would get the desired results. I'm imagining the puddle lights coming on if I turn on the dome lights going down the interstate or something, maybe it's not a big deal.
Thanks.
Old Nov 19, 2012 | 06:19 PM
  #73
05z71's Avatar
Looking for some guidance please.
I picked up some 05 fully electric/leather seats and am going to put them in my 07 classic work truck.
The harness plugs are close size wise but won't snap together because of a plastic finger sticking out of the seat harness.
What I'm trying to find is a schematic for the loaded seats so I can just wire up all the motors and get it working. not worried about the air bag sensors or the heaters, just what I need to supply ign12v and ground to.
Thank you.
Old Nov 20, 2012 | 06:07 AM
  #74
CalEditor@PCMCalibrators's Avatar
FormerVendor
I will pull that up for you
Old Nov 20, 2012 | 12:04 PM
  #75
FormerVendor
2005 GMT-800 Seats
Drivers Seat Connctor
Drivers Seat 6 way (AG1)
Power - Ground - Serial Data - Seat Controls AG1 with AN3
Seat Motors AG1 AN3
Heated Seats AN3
Passengers ---- Power - Ground - Serial data - Seat Controls
Pass --- Heated Seats
Old Nov 20, 2012 | 12:07 PM
  #76
FormerVendor
Default 2007 gmt-800
2007 GMT-800 seats
Drivers Seat Connector
Drivers Seat --- 6 way
Drivers Seat --- Power - Ground - Serial Data - Seat Controls
Drivers Seat --- Seat Motors and Position Sensors
Passengers Seat
Old Nov 20, 2012 | 07:59 PM
  #77
05z71's Avatar
Thank you very much. Made some jumpers and got the seats adjusted for now.
Old Dec 2, 2012 | 11:09 AM
  #78
CoreyO93's Avatar
Can i get a pinout for ECU on a 2011 silverado 1500 6.2L need to locate egr pin to connect wideband for autocal tuning
Old Dec 15, 2012 | 06:46 PM
  #79
greasemykey's Avatar
i dont know where else to turn for advice so i am trying here. i bought a "uncut" wiring harness from a member on here who didnt tell me the neutral safety switch plugs were missing. while trying to solder in new connectors i have come across multiple wires that are the same color. can you pull a diagram up that shows me where all the wires come from so i can ohm out each wire to make sure its connected correctly please.
Old Dec 23, 2012 | 06:05 PM
  #80
jschrock's Avatar
Can I get a schematic for the starter? 2003 GMC Sierra SLE 5.3
