Running Lean!!!!!
Old Nov 25, 2007 | 10:31 PM
  #91
v8
17,16,15,14,13,12,11 Drvr
Originally Posted by closet red neck
How do I find the IDC using HPT???
look in your scanner and pull up chart display, the one we looked at friday night, it has your inj. duty cycle in it about 1/4 way down.
  #92
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Go to sleep you grumpy bastard
Old Nov 25, 2007 | 10:32 PM
  #93
v8
who me ahhahaa
Old Nov 25, 2007 | 10:33 PM
  #94
TouchOfEvil04's Avatar
Yep just pull up the log graph and take a look. You can't miss it. It will say IDC and have a percent. Scroll across to a spot where you went WOT and look at what the number says on it across the whole WOT session.
Old Nov 25, 2007 | 10:34 PM
  #95
closet red neck's Avatar
The IDC was 61%. This is the highest %age that was recorded.
Old Nov 25, 2007 | 10:37 PM
  #96
Rhino79's Avatar
9 Second Club
Put a pressure gauge on it and check it at WOT. You really should be around 58-62 psi and then get the tune dialed in. Set the PE values, disable MAF, tune VE, enable MAF then tune it. Hope you get it lined out, you have plenty of injector, so make sure the pressure is stable and watch the IDC. If the IDC is hitting above 100% then its a pump problem, if not, then maybe in the tune.
  #97
litreddevil's Avatar
Banned
bang::ba ng::bang :man this **** pissed me off i am not going to retype it i had a big long deal but for some reason it did not come up.
Old Nov 25, 2007 | 10:38 PM
  #98
Then the pump is fine and you just need to tune out the bug is all.
  #99
Rhino79's Avatar
9 Second Club
**** I was typing while you were, well the IDC is good so the pump is fine. Go thru the steps I put in the previous post, you'll get the AFR on the money then. What is your AFR at WOT now?
Old Nov 25, 2007 | 10:39 PM
  #100
Originally Posted by litreddevil
bang::ba ng::bang :::man this **** pissed me off i am not going to retype it i had a big long deal but for some reason it did not come up.
LMMFAO!!!!!!!!!!!!!!
