Running 35* timing with no KR!!!!!!!!!!
#24
Originally Posted by TouchOfEvil04
So it hits 6ms at a certain point alread right?Have it changed so that all the scales that are lower than the 6ms area up to 6ms correct>?Then have the multi set up to 1.0 correct?
I'm just bad at explaining things. LOL
#25
Originally Posted by Snake Eater
Your right on the money.
#26
Where in HPTuners is this located? Im assuming in the Engine>Spark Dwell... and then where?? Under Base Dwell time it is listed by volts and RPMs so where did you make the changes?? Thanks for the tip!
#27
I'm stationed at Brunswick NAS. I "should" get out in July if they dont extend me again. The sooner the better.
What is the local "scene"? Where is Milo?
#28
