replace fuel pump
Old Nov 3, 2008 | 01:22 PM
53RUSSELL's Avatar
Default replace fuel pump
I replace my fuel pump with waldo 255. Fuel gauge read 58 psi with no vacuum and 50psi with vacuum. when turn the key pump comes on and goes to 60psi and when pump goes off drops to 0psi. The other problem is that my a/f +17 at idle. I changed the fuel regulator already. What do you guys think.
Old Nov 3, 2008 | 02:01 PM
sharpshooter's Avatar
check valve problem on pump
Old Nov 4, 2008 | 10:46 AM
hog's Avatar
hog
How does it idle? 17:1 is pretty lean some widebands arent very good at idle. What are your NB O2's and trims telling you at idle?
How does the truck drive. How's the idle in gear?
Your FPF sounds fine, and I agree sounds like the pump is letting fuel back into the tank. Could have a leaky injector as well.
peace
Hog
Old Nov 4, 2008 | 12:11 PM
53RUSSELL's Avatar
peace
Hog
Well replaced the injector with 42's when i did the pump. I'm wonding if just need to redo my V.E table and short fuel trims were +35% when a/f cam back around 15 then when rev up the trim go back to +5% and the a/f goes to 19.1 and works way back to 35% on the short fuel trims. I'm thinking i should redo my v.e table for the bigger injector. I'm runnin co3 sem-closed looped and changed my fuel rate allready.
Old Nov 4, 2008 | 05:07 PM
phasemaster1's Avatar
Yeah you better tune for those 42# injectors.
slowlsx
Aug 13, 2015 08:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
