Repinning pcm
Old Feb 25, 2014 | 10:22 PM
Tip1500's Avatar
Default Repinning pcm
Aye guys! I'm swapping a vortec 355 into my 90 Silverado with a 305. I was told to get a pcm out of a 95 Tahoe and convert the 90 harness into the 95 pcm. Is it that easy!? If so is there a diagram available so I can pin it correctly. Thanks!
Old Mar 2, 2014 | 08:31 AM
Tip1500's Avatar
Really need help on this. Searches come up with conflicting results. Also can I run with my stock TBI of do I need the 454 TBI? Anyone who's done this please chime in.
Old Mar 3, 2014 | 09:14 PM
You can buy a subscription to all data give you full access to schematics trouble trees dtc codes everything. In my opinion we use it at the shop and it's better than some of our OEM reference materials sometimes. Also remember you need to go to a heated 3 wire 02 for the 95 pcm. I use a 95 350 truck 02 and a heated 02 conversion harness from racetronix on the ones I've done.
Old Mar 4, 2014 | 09:31 AM
Tip1500's Avatar
Sorry but what's a heated 3 wire 02? Is it short for 02 sensor? And will the stock TBI be enough?
Old Mar 4, 2014 | 04:22 PM
Yes heated oxygen sensor. You need to find a 350 throttle body and it will be fine. My memory's getting rusty but I vaguely remember the 350's have bigger injectors but other than that identical throttle body.
Old Mar 5, 2014 | 05:53 AM
Tip1500's Avatar
I'm watching a couple on eBay. I also was thinking the injectors could be changed in my current throttle body to match the 350's.
Old Mar 5, 2014 | 05:28 PM
Yes you can swap injectors only.
Old Mar 5, 2014 | 06:24 PM
Tip1500's Avatar
Great! Man I really appreciate your help! As soon as I get tha parts together, I'll up date you on tha outcome!
Old Mar 5, 2014 | 06:35 PM
Tip1500's Avatar
Old Mar 5, 2014 | 06:40 PM
Tip1500's Avatar
Ok I have set up a account with Racetronix. What part # O2 sensor do I need to look for?
