Reduced Engine Power p0101 p0106
Old Jan 15, 2009 | 09:44 PM
Fara04's Avatar
Ok I have a 6.0 lq4 full bolt ons No stall, and I recently put a 232/234 torquer v2 Cam which I havent been able to take to get tuned bacause of the same problem my tuner cant get an acurate reading becaue of the MAF
Old Jan 15, 2009 | 09:48 PM
Fara04's Avatar
Only thing my tuner did was raise the idle so my truck wouldnt turn off, but like I said once in a while it will start bogging and turn off with reduced engine power
Old Jan 15, 2009 | 09:55 PM
parish8's Avatar
single digit dreamer
stock stall with that cam is not going to be a good combo and might be part of your tuning issues.
Old Jan 15, 2009 | 09:58 PM
v8
17,16,15,14,13,12,11 Drvr
sounds like your maxing out your map sensor at idle causeing the other problems, he needs to set the max to 75 and leave the min stock just in case it does it fail.
p0121 is the map sensor code.
Old Jan 15, 2009 | 10:03 PM
BlackGMC's Avatar
Resident Retard
Since your getting a MAP and MAF code, and then it goes into REP, I think it might be the values in your MAF rationality test table... I believe the REP gets set because there is toooo big of a difference between your MAP and MAF.... Did your tuner tune both your VE and MAF tables or just the MAF table?
Fara04's Avatar
Yea I know Parish im fixing on getting one next week, so you think that can be part of the problem?
Old Jan 15, 2009 | 10:05 PM
BlackGMC's Avatar
Resident Retard
Definition of Map Rationality Test table...
"This table defines the maximum difference that is allowed between the calculated airflow (using MAP) and actual measured airflow (MAF)."
Fara04's Avatar
Ill let him know, maybe he can chime in on the Forum to post up
Old Jan 16, 2009 | 08:34 AM
dc_justin's Avatar
Hello Dave
Bingo. Something isn't right with the tune. If either VE or MAF were changed to values they should be, then the MAF Rationality test would not need to be changed. Mechanical problem could be faulty MAF (replaced), Faulty MAP (P0106 lends to this), plugged converter(s) (both codes could be caused by this).
If there was a broken wire, P0102 would trip... low frequency code.
Old Jan 16, 2009 | 01:12 PM
Fara04's Avatar
Thanks guys
