Reduced Engine Power p0101 p0106
Old 01-15-2009, 07:54 PM
Fara04's Avatar
Default Reduced Engine Power p0101 p0106
Ive been getting these codes the MAF censor has been replaced and the code still comes up, also once in a while my truck will start to bogg and it will turn off with the reduced engine power I have to disconect the battery in order to turn it back on, can anybody help me out I went to go tune my truck but my tuner said he couldnt do a wideband because he couldnt get an accurate reading because of the MAF censor this was before I replaced it for the new one. Can anyone help me out
Old 01-15-2009, 08:23 PM
v8
17,16,15,14,13,12,11 Drvr
p01514 and p0068 max out both, good luck.
Old 01-15-2009, 08:26 PM
Fara04's Avatar
what does that mean?
Old 01-15-2009, 08:36 PM
v8
your tuner should know.
Old 01-15-2009, 08:37 PM
single digit dreamer
parish8's Avatar
isn't that what you would do for code p0103? "mass airflow sensor circuit high"
not sure if what you are pointing him too will help with the codes he is seeing. i am no pro on the tuning the stock ecm so correct me if i am wrong.
Old 01-15-2009, 09:08 PM
v8
http://www.hptuners.com/forum/showth...d+engine+power
maybe this will help
p0106 is the map sensor code.
p0101 is the maf performance code
but since you replaced the maf the codes I said seem to work most of the time.
you could also have a cut wire to the maf, good luck.
Old 01-15-2009, 09:19 PM
Fara04's Avatar
Ill check on that thanks v8, anyone else with same problems???
Old 01-15-2009, 09:26 PM
parish8's Avatar
i am familur with that situation. when it happend to me it set a p0103 code and some kind of tps code. not the 2 codes he is seeing.
Old 01-15-2009, 09:35 PM
Resident Retard
BlackGMC's Avatar
More info on your setup my help too
Old 01-15-2009, 09:40 PM
v8
probably a p0121 ahhaha
only thing I can think of is he has a broken wire some where or the map sensor is bad as well.
Quick Reply: Reduced Engine Power p0101 p0106
