Reduced Engine Power Code
Old Oct 22, 2012 | 10:29 AM
04Yukon's Avatar
Default Reduced Engine Power Code
I had my Yukon tuned by mean05 back in 2008. Recently started getting Reduced Engine Power on a frequent basis. I've done research and found it could need a tune update. mean05 will not respond to vm, text or pm's. So my question is: is it possible to have someone else work the tune? If so, who in the Mesquite, TX (or Dallas) area does reliable work?
Old Oct 22, 2012 | 10:50 AM
Gadgetized's Avatar
It will not just throw a code because it needs to be updated. There is a problem somewhere. What codes is it throwning when it goes into REP?
Old Oct 22, 2012 | 11:08 AM
TXSZ66AVLANCHE's Avatar
^ what this guy said
Old Oct 22, 2012 | 01:46 PM
KLUG'S SS's Avatar
FormerVendor
These darned drive by wire trucks have been known to have the throttle bodies go bad, the throttle position sensors in them can take a crap and then it will want to go into REP mode.
Had one go bad on my 03 this summer, had a p2135 code and anything over 10% throttle and truck would go into REP. The p2135 I had when mine went bad if I remember just off the top of my head said something to the effect of tps correlation issues between sensors A and B.
Old Oct 23, 2012 | 09:18 PM
1FastBrick's Avatar
Custm2500's Rude Friend
GM also has a TSB about the wiring becoming brittle and breaking.
Without the trouble code's we don't know where to point you.
Old Oct 23, 2012 | 09:49 PM
KLUG'S SS's Avatar
FormerVendor
Yes they did, good point bringing that up I forgot about that. The part of the wiring harness that goes to the throttle body. Their is a good set of test procedures I found online before that are right from the GM service bulletin that explain what wires to check out and whether or not it's a wiring issue or the throttle body itself. I think their have even been some cases where the TAC (throttle actuator control) module on the firewall has been bad as well.
Old Oct 24, 2012 | 05:35 AM
Had problems with mine most of the summer, finally fixed it be replacing wiring all the way back to the tac module.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
Ketis
Jul 23, 2015 12:37 PM
bsgiffor
Jul 19, 2015 11:14 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
