reduced engine power after torque converter install
Old Sep 16, 2012 | 09:23 PM
kelsey_canard's Avatar
Default reduced engine power after torque converter install
Got my converter installed 2 nights ago, which I have been very pleased with so far, but went into rep mode. I've put probably 30 miles on it since I've installed it and only tripped it once. I noticed the neutral saftey switch (box by the linkage) was a little messed up. Looked like it had been off before and had a crack in the casing. Could this switch going bad cause the rep? Any insight let me know. Thx guys
Old Sep 16, 2012 | 11:06 PM
Pulled the code. Showed p1516. Is there a possibility that the tranny dipstick got into the ground?
Old Sep 17, 2012 | 12:16 AM
casper02's Avatar
check ur ground wen i did my install i messed one of them up
Old Sep 17, 2012 | 12:18 AM
Its the one that goes in the back of the block right? If u completely broke the wire, then I would be in rep all the time right? Do I just check the wire for a short?
Old Sep 17, 2012 | 05:20 AM
Gadgetized's Avatar
Check both of them at the back of the engine. Pass side should be on the head, drivers side should be on the block near the head.
LCHEE
Oct 24, 2020 04:10 PM
TAPyvehc93
Jul 23, 2017 10:54 PM
BennyB
Aug 1, 2015 08:48 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
JordanH
Jul 14, 2015 03:46 PM
