rebuilt lq4 wont start
Old 10-09-2012, 07:57 AM
SPAM HUNTER
2005 Silverado's Avatar
Originally Posted by 2doorfury
So its not hooked to the top of intake?
Nope
Originally Posted by sand man
check the EVAP silonoied (poor spiling ) but you know what I mean
Efi live clicks it.
Old 10-09-2012, 08:02 AM
Nflddog1000's Avatar
Sounds like timing u got any codes, cam sensor
Old 10-09-2012, 09:09 PM
SPAM HUNTER
No codes or well i got a p0315 today. Timing is on I checked it. I taking a rest from it working on my air compressor restoration and 36" lathe clean up.
Old 10-13-2012, 09:00 PM
SPAM HUNTER
Changed out crank and cam sensors no change. Any others have any ideas.
Old 10-13-2012, 09:34 PM
whitedakota's Avatar
I'd say outta time.. But you verified it wasn't. Can't it be 180* or something similar to an old sbc? Cam wise?
Old 10-14-2012, 09:00 PM
SPAM HUNTER
I checked dot to dot. So unless the sensor is reading the cam wrong idk what else to check.
Old 10-14-2012, 09:22 PM
01silvy's Avatar
It deff sounds like the timing is off to me too, but since you verified that then i dont know. Did you turn the engine over by hand before final assembly to make sure everything turned over smooth?
Old 10-14-2012, 09:42 PM
SPAM HUNTER
Sure did. When I installed the rockers spun it to retorque. I guess ill tear it down again.
Old 10-15-2012, 01:51 AM
Custm2500's Rude Friend
1FastBrick's Avatar
Stock cam, lifters, and push rod's???
P0315 is crankshaft variation not learned.
I wonder if there is an issue with thrust / end play or if the crank wheel is damaged.
Did you change/ modify the tune your self??? Are you sure you adjusted everything correctly???
Old 10-15-2012, 09:08 PM
SPAM HUNTER
Comp xr281hr, ls7 lifters, 7.350 comp pushrods. I took the best care of the crank I could. I'm trying to tune it myself.
Quick Reply: rebuilt lq4 wont start
