Random misfire at high loads
Old Jun 25, 2016 | 01:38 PM
LOWZ71GA's Avatar
Registered User
Default Random misfire at high loads
Im getting random knock, especially at higher loads and feel its a sensor or maybe ground. My question is what order should I follow in diagnosing/ replacing sensors?
Ive replaced plugs/wires and replaced MAF sensor with known good unit. I have a 5.3 that I can trade sensors with.
Old Jun 27, 2016 | 08:27 PM
MikeGyver's Avatar
Make up your mind, is it knocking or is it misfiring?
Old Jun 28, 2016 | 08:31 AM
LOWZ71GA's Avatar
Registered User
What it cant do both??*? Its missing badly,all on bank 2. Its also showing knock. Ive now replaced plugs, wires, coil pack on b2, 02 sensors, maf, map with no change. Could a faulty crank or cam sensor be causing this issue?
Old Jun 28, 2016 | 11:34 AM
madmann26's Avatar
Could be a coil going bad. Swap it to a different cylinder to see if the problem follows. If it does, then you've found your issue.
If not, keep looking.
Old Jun 28, 2016 | 11:39 AM
LOWZ71GA's Avatar
Registered User
Madmann I swapped entire bank from another 5.3. Only two sensors I havent swapped are crank and cam.
Old Jun 28, 2016 | 07:03 PM
Last Call's Avatar
TOTM: January 2007
How did the plugs that you pulled out of Bank 2 look? Any signs of oil ingestion or excessive fuel from the plug not firing?
Old Jun 29, 2016 | 10:28 AM
LOWZ71GA's Avatar
Registered User
They looked really close to the plugs on bank 1. I changed out crank sensor with no luck. Last sensor I can change is cam sensor. Im going to try and pop it out without pulling intake but if not i will bite the bullet.
Im getting a little bit of misfire on cylinder 3 now and its def not drivabl . Cant even do a crank relearn as it wont rev past 3k.
KleanKustoms
May 5, 2016 09:30 PM
racin1291
Apr 20, 2016 08:55 AM
casper02
Apr 14, 2016 02:43 PM
chaosz71
Mar 29, 2016 05:21 AM
Shtbox
Mar 28, 2016 04:31 PM
