Radix Supplied tuning
Old Aug 21, 2005 | 12:53 PM
OCBC's Avatar
Default Radix Supplied tuning
Does the tuning supplied with the radix kit change any of the shift pressures or remove any type of tq management?
Just curuois about what to do If I have a shift kit installed etc?
Old Aug 21, 2005 | 12:56 PM
wkdivr's Avatar
When you order the kit, you tell them if you have a shift kit, or any other mods. They can tailor your kit to what you have in your truck.
Old Aug 21, 2005 | 12:57 PM
moregrip's Avatar
what a rush!
yes to both.
tell magnuson that you have a shift kit when you order it so they can adjust for it.
Old Aug 21, 2005 | 03:27 PM
OCBC's Avatar
ok, so you can have them do basically what you want. Along the same lines they can account for all mods? Turn on the fans etc?
Old Aug 21, 2005 | 09:47 PM
Crash Dummy's Avatar
Former Moderator :(
The Magna Charger tune is a EO approved tune up and the supplied pulley and tune makes it a 50 state legal kit. Tire size,gear ratio, and with or without a shift kit is about the only items that can be changed. Changing any of the fuel and spark tables would violate the EO tune to a non emmision off road status. All most all the torque managment is removed in the stock Magna Charger tune and the fans are set as low as possible for a stock 195 thermostat. Any other adjustments would require a custom tune and that would void the 50 state EO status.
zblee
63
Jun 10, 2023 01:25 PM
The_W
Aug 15, 2015 08:07 AM
therock
Jul 25, 2015 09:23 AM
Gadgetized
Jul 22, 2015 11:55 AM
sTNT971
Jul 16, 2015 12:39 PM
