radix and IAT correction table
Old Jul 21, 2005 | 10:48 AM
BlownChevy's Avatar
blownerator
25 Year Member
Originally Posted by JohnUlaszek
Thanks Moregrip,
It is a two part article, the results are in the next issue. I ran out of space to cover everything I wanted to this month.
The big thing is that heat soak will cause the Radix's IAT to report a different air temp than is actually going into the cylinder heads. If you look at the pictures in the article, you can see the pyrometer is pointing deep into the intake runner.
Old Jul 21, 2005 | 11:21 AM
moregrip's Avatar
what a rush!
Thanks Moregrip,
yes, i saw where you mounted them, very nice work.
Old Jul 21, 2005 | 03:04 PM
zippy's Avatar
i use almost the entire IAT table.
Old Jul 22, 2005 | 03:31 PM
dewmanshu's Avatar
Moderately Differentiated
really? why? do you just shoot for a high advance table and let the temperature dictate what you get?
Old Jul 22, 2005 | 06:05 PM
zippy's Avatar
something like that. i try to tune for a base temp. to go off of. from there i try to get the intake temps in all the ranges and see where i can add or subract. there's no point in locking in one number if i can add a bit when it's cool air. in the other case, why run a low base timing if i'm only going to see a problem when the IAT's are high. i use both the coolant temp and the IAT. to make this work properly though you have to get the base timing set where you want it first under the same conditions every time. once you do that adjust for other conditions in the IAT and ECT tables. here's an example from a truck i have almost a hundred reflashes in.
Old Jul 23, 2005 | 10:30 PM
dewmanshu's Avatar
Makes sense. Wish I had the time these days to build a base time table.
Old Jul 30, 2005 | 12:09 AM
onyx's Avatar
14 Second Truck Club
Originally Posted by dewmanshu
How much timing and where (cylinder airmass vs temp) R you radix guys telling IAT Correction Table to adjust? Just curious...where is your threshold...if any.
where is this VE located at?... i cant find it.
SloSVO
Nov 22, 2020 07:34 PM
Vortec350ss
Jan 12, 2016 10:36 PM
Gadgetized
Oct 22, 2015 09:06 AM
JordanH
Oct 3, 2015 03:59 PM
bagged7104SS
Sep 24, 2015 08:42 PM
