Question About A/C After Nelson Harness Install
Some files below that should help. Right click and save as. Hope they help.
Aftermarket Wire Harness Schematic
Step AC Troubleshoot
GM AC Schematic
GM AC Schematic
I had the exact same thing happen to me last nite, Got the fans on. They come on at the desired temp however it seems like the A/C will not kick on, even with defrost. So what is up with this problem?
I am still working on it I really have no clue and I thought I was pretty good with wiring. I will keep you posted. I called Allen Nelson but he has yet to return my call and I called him I think Thursday.Also let me know if you find out anything.
I'd say unhook the Nelson harness from the AC feed to rule it out? Also verify that you are tying into the DK Green wire to the compressor. Wire 59 in the AC schematic I posted above. Works just as its supose to on mine.
Here is a photo I outlined where the to find the green wire. Traced the wire loom in yellow and circled in yellow where I tied in. You can see the tape where I secured it when done.
KY- That is exactly where mine is tied in at, did some more playing around today, It seems like the defrosters are working. The thing that I am not sure of is the fan only kicks on high for a couple seconds when the defrosters are turned on, I was under the impression that one would stay on high the whole time the a/c was being used? Also, tried unplugging the a/c tap and makes no difference in how anything works.
How do I change this text
If that is the case, the wire tap used to tap in to the green wire may have cut the wire in two. Unplug the pig tail at the A/C check for power at the tap and at the A/C plug. (Move the wire around were the tap is during test)
If power is at both places the problem is on the ground side of the A/C clutch.
But if you have power at the tap but not at the A/C pig tail the wire is cut................... somewhere
